Results 21 to 22 of 22
BANNED BANNED BANNED
- Jul 2013
- 421
June 11th, 2016 04:40 PM #21Sobra namang napakatxxx ang mga electrician.
kung normal ang charging mo (which could be ascertained with a simple reading while revving the engine, a simple check (engine off) with an analog tester in series with the positive cable will show you the amount of current drain. Using a screwdriver and an idiot bulb....aru, diyos ko.
June 12th, 2016 11:50 PM #22
don't laugh, i used this in the 80's when i worked for a general motor dealership.
it turns the light on when conducting parasitic drain test when the current is +/- 30 milliamps. sure it did not tell you how much but it will be less than 30mA, the most common parasitic load at the time.
http://www.walmart.com/ip/Thexton-Th...758354&veh=sem
now this is one of the tools i use for this test
fuse buddy ammeter - Google Search
Xiaomi E-Car
