Results 11 to 19 of 19
- Jul 2010
- 570
November 27th, 2013 01:23 AM #11Normal lang iyon high current na iyon.
Actually , aircon compressor have no electrical connection. Pulley driven ito. Ang nakikita ko lang pwede mag create ng high surge current ay mga dc motor. Gaya ng Condenser Fan and Blower Fan and which will turn on if aircon was activated . DC motors tends to draw high current due to its inductance and commutator inertia. But once the commutator have already gain its speed. The high current will drop to its normal dc motor drawn current. Sometimes we call it startup current.
- Jul 2010
- 165
November 27th, 2013 07:44 AM #12
November 28th, 2013 08:29 PM #13
November 28th, 2013 08:34 PM #14
hindi naman lampas 60 amperes...between 10-30 amperes (all loads are off). saka lang nagoovershoot kapag after starting, A/C on and even headlights on. then go down to about 40 Amps.
check ko uli kapag ibalik na nya sasakyan nya. yun ay kung babalik sya agad. eh hinete pinsan ko e. saka lang may ipapatingin kung talagang sira na. hehe
- Jul 2007
- 26
August 16th, 2018 06:15 PM #15i went to my electrician with an ampere guage, he said that is not compatible with your car, that is only up to 60..... you need something up to 90.
if found out that amp guages up to 60 are for cars with voltage regulators...... mine daw is IC type.....whatever that means......i googled it and there really are amp guages even up to 150.
- 52,731
August 16th, 2018 10:54 PM #16
August 17th, 2018 07:11 AM #17
Don't forget the possibility the ammeter was connected wrong or was Installed near a strong magnet
- 52,731
August 18th, 2018 12:23 PM #18in the 60s, most jeeps were fitted with ROX ammeters. up to +/- 50 or 60 amps lang sila. and every driver would look at it upon starting, to see if the generator (not alternator) were charging.
la lang.. surfing.Last edited by dr. d; August 18th, 2018 at 12:26 PM.
- Nov 2009
- 3,484
August 18th, 2018 02:20 PM #19Analog Ammeters are not recommended if not properly wired.
Check the main fuse of your battery then you will have rough estimate of what amperage to use.
It should be more than the main fuse if you will wire it directly from alternator to battery, else the gauge will go first before the fuse which could start a fire. A burnt wire insulation is a trigger to a fire because anything burnt is carbon which conducts electricity.
To answer the TS, there is no such as giving overcurrent, maybe over current draw. The clutch of AC is a huge electromagnet like a motor that draws huge amnt of current when engaged.
Xiaomi E-Car
