Results 11 to 14 of 14
- 52,731
March 30th, 2014 09:23 AM #11ibig mong sabihin, tinaas mo ang idling speed mo dahil nanginginig nga siya?
if your idle up is working, you wouldn't have to tinker with your idling rpm setting.
rpm drops when braking? sounds like your idle air bleed screw is too tight. this might also be the reason for the nginig.. open her up by 1/2 to 3/4 turn counterclockwise.. but if there is no improvement, ibalik mo sa original setting, para isa-isa mong ma-shoot the trouble..Last edited by dr. d; March 30th, 2014 at 09:26 AM.
- Dec 2013
- 22
- Feb 2014
- 112
April 8th, 2014 11:12 AM #13ganito po ang problem ko e, bumababa ang rpm pag umapak ng brake.. noticeable sya pag ung tipong stop and go ang traffic at nakaalalay sa brake kc AT po ung oto. paano po ba iadjust un? kasi po sa dami ng mechanic na napagsabihan ko ng prob ko, ni isa sa kanila wlang naka resolve.. kesyo bka engine support daw, pero pag check ng engine support buo naman. so after that, wla na silang ibang maisip.
- Feb 2014
- 112
April 8th, 2014 11:33 AM #14
high idle RPM at engine start
