Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Sep 2013
    Good Day!
    I badly need all your opinions. My ride is Honda IDSI 2003 A/T - wala talaga ko alam in terms of sira ng sasakyan. Sabi ng mekaniko
    sira velocity joint and brake pads so pinagawa ko at naayos naman at nakauwi pa ko. BUT after 1-day while pedalling on the gas parang nag-stastumble then namatay, pero kapag restart okay naman aandar ulet. Then kanina twice umandar saglit then namamatay ulet.
    Ayaw naman tingnan ng service center sa Petron kase hindi daw sila gumagawa ng electrical, na tingnan naman sparkplug okay pa naman daw. So, anong problema bakit bigla sira?
    Kanino ko po papagawa sa mekaniko po ba or electrician? at saan po maayos
    By the way, kakapa change oil ko pa lang 2 months ago. Bago a/c compressor ko. As in maayos naman kotse ko. All of a sudden ganito na ngaun.
    Please help.
    Thank you.
    Quote Originally Posted by Judie Aguilar View Post
    Good Day!
    Please help.
    Thank you.
    madaming pwede eh.
    pwedeng sa distributor.
    pwedeng sa spark plugs.
    pwedeng sa maf sensor.
    kamusta idling nya?
    Sep 2012
    Quote Originally Posted by 1D4LV View Post
    madaming pwede eh.
    kamusta idling nya?
    to add >>> pwede rin nakapag karga sya ng gasoline na may halong tubig...
    Oct 2011
    pa check na lang sa speedyfix para cgurado tayo kung ano ba ang problema.
    Sep 2013
    Sabi ng electrician EPS. Possible kaya?
    My Honda City 2008 1.3AT is presently experiencing the same symptom lately. As claimed by my GF who uses the car, mga 3 or 4 times na nangyari for the past 2 months, tumatakbo sya then parang papalya na tipong babagsak idling kahit diinan mo pa yung gas pedal tapos mamamatay na ng tuluyan yung engine. Pero I-start mo ulit, aandar naman ulit tapos ok na ulit. Pansinin din nya na lumakas sa konsumo ng gas. Up to now di pa rin malaman kung ano problema.
    Quote Originally Posted by Wishing View Post
    looks like an ETCS (electronic throttle control system) problem. very common to 2006 to 2008 models. have it scanned and see if it has dtc P1659
    Aug 2010
    Good Day!
    Please help.
    Thank you.
    Sir, nung pina service mo iba items sa car mo, disconnect nila battery? Gaano na katagal yung spark plug mo? Same tayo ng ride at na-experience ko yung ganyang namamatayan bigla. Pag start OK naman. Bale palit kami ng sparkplugs since yung ang pinakaaccessible at palitin na yung sa amin (1 year na). As mentioned by other TS, ok ba idling?
    Sir t2terns, thank you very much sa suggestion. Sige sir ipapacheck ko.
    Sir alfonsomiguel, medyo bitin ako dun sa first question nyo, "kung diniskonek yung battery". I've heard of Honda City iDSL models that needs re-setting of computer once the battery gets disconnected. My question is will the car exhibit the same symptoms like mine and Ms. Judie Aguilar's if our computer needs resetting?
    Aug 2010
    Sir Wishing, previously na-disconnect na battery nung nagpalit ako battery. For sometime, wala naman ako naramdaman na iba. Until nung nagpa-service ako dahil nga namamatayan ako. Tinanong ako nung mechanic kung na disconnect ang terminals. Sabi ko nung nagpalit ako battery 5months back. So ginawa nya, check lahat ng spark plug at nakita 2 plugs na pangit ang sunog. After mapalitan 8 na plugs, di na sya namamatayan for 2 months now.
Loss of Power
