Results 1 to 10 of 22
- Sep 2013
- 5
September 9th, 2013 03:21 PM #1Good Day!
I badly need all your opinions. My ride is Honda IDSI 2003 A/T - wala talaga ko alam in terms of sira ng sasakyan. Sabi ng mekaniko
sira velocity joint and brake pads so pinagawa ko at naayos naman at nakauwi pa ko. BUT after 1-day while pedalling on the gas parang nag-stastumble then namatay, pero kapag restart okay naman aandar ulet. Then kanina twice umandar saglit then namamatay ulet.
Ayaw naman tingnan ng service center sa Petron kase hindi daw sila gumagawa ng electrical, na tingnan naman sparkplug okay pa naman daw. So, anong problema bakit bigla sira?
Kanino ko po papagawa sa mekaniko po ba or electrician? at saan po maayos
By the way, kakapa change oil ko pa lang 2 months ago. Bago a/c compressor ko. As in maayos naman kotse ko. All of a sudden ganito na ngaun.
Please help.
Thank you.
September 9th, 2013 05:31 PM #2
September 9th, 2013 06:18 PM #3
September 9th, 2013 07:21 PM #4
pa check na lang sa speedyfix para cgurado tayo kung ano ba ang problema.
- Sep 2013
- 5
- Jul 2009
- 153
September 10th, 2013 10:15 AM #6My Honda City 2008 1.3AT is presently experiencing the same symptom lately. As claimed by my GF who uses the car, mga 3 or 4 times na nangyari for the past 2 months, tumatakbo sya then parang papalya na tipong babagsak idling kahit diinan mo pa yung gas pedal tapos mamamatay na ng tuluyan yung engine. Pero I-start mo ulit, aandar naman ulit tapos ok na ulit. Pansinin din nya na lumakas sa konsumo ng gas. Up to now di pa rin malaman kung ano problema.
September 10th, 2013 02:26 PM #7
- Aug 2010
- 86
September 10th, 2013 03:13 PM #8Sir, nung pina service mo iba items sa car mo, disconnect nila battery? Gaano na katagal yung spark plug mo? Same tayo ng ride at na-experience ko yung ganyang namamatayan bigla. Pag start OK naman. Bale palit kami ng sparkplugs since yung ang pinakaaccessible at palitin na yung sa amin (1 year na). As mentioned by other TS, ok ba idling?
- Jul 2009
- 153
September 10th, 2013 06:12 PM #9Sir t2terns, thank you very much sa suggestion. Sige sir ipapacheck ko.
Sir alfonsomiguel, medyo bitin ako dun sa first question nyo, "kung diniskonek yung battery". I've heard of Honda City iDSL models that needs re-setting of computer once the battery gets disconnected. My question is will the car exhibit the same symptoms like mine and Ms. Judie Aguilar's if our computer needs resetting?
- Aug 2010
- 86
September 10th, 2013 09:42 PM #10Sir Wishing, previously na-disconnect na battery nung nagpalit ako battery. For sometime, wala naman ako naramdaman na iba. Until nung nagpa-service ako dahil nga namamatayan ako. Tinanong ako nung mechanic kung na disconnect ang terminals. Sabi ko nung nagpalit ako battery 5months back. So ginawa nya, check lahat ng spark plug at nakita 2 plugs na pangit ang sunog. After mapalitan 8 na plugs, di na sya namamatayan for 2 months now.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
Which is better? Amaron or Panasonic Battery?
