Results 11 to 17 of 17
- Jul 2009
- 2,618
May 11th, 2020 04:57 PM #11
- 52,765
May 11th, 2020 05:21 PM #12
May 11th, 2020 10:59 PM #13
For engines bigger than 2000cc, especially for a diesel, there is a technique for using it. Same as in using a jumper, it will only work IF your car battery still has some charge and can still receive a charge. So like when you use a jumper that you connect to the battery of another vehicle, you are NOT using the other vehicle's battery SOLELY to start your car, you first use it to charge your discharged battery. After revving the other car for a minute or two the "dead" battery would have taken enough charge and that plus the other car's charging system is enough to crank your engine. So when you use the Li-Ion battery you connect it, wait 1 minute for the charge to transfer to the dead battery then crank the car.
I've used mine 2x, once with success and the other failed. It was able to start a kia sorento 2.2 using the above technique. With a dead battery on a 3.2 ford everest di kinaya. Nag crank siya pero sobra mabagal.
- 52,765
May 11th, 2020 11:22 PM #14
May 11th, 2020 11:30 PM #15
- 52,765
May 11th, 2020 11:44 PM #16
- Jan 2008
- 4,726
May 11th, 2020 11:46 PM #17
The ₱613,000 discount is until June 31, 2024. Note that the Peugeot 5008 used to retail over 3M...
2018 Peugeot 5008
