Results 1 to 3 of 3
- Sep 2008
- 33
November 27th, 2008 05:11 PM #1i have a problem with my instrument cluster
Lancer '97 GLXI
sometimes the Tachometer and Speedometer and Odometer dies, indicating nothing. fortunately the gas and the temp seem to be working.... then it turns on again... then off again. sometimes mga 30 minutes naka-on tapos mga 15 minutes naka-off... grr....
steps i tried to do:
- cleaned the terminals and connectors sa likod ng guages. malinis na lahat.
- checked the connector to the speedometer, ok naman
- checked the connector to the engine speed sensor, ok naman...
- checked the fuses.. ok naman lahat...
the previous owner may have messed up the instrument cluster nung nagpalagay siya ng indiglo....
asked kung magkano ang mga surplus na guages... mga 4k-5k... sayang pera eh... just wanted to know if anybody has the same problem... baka na-solve ninyo... at makatipid ako ng 5k...
thanks
THE AUTO SPECIALIST
- Mar 2006
- 607
November 27th, 2008 10:49 PM #2kailangan diyan scan test muna and then go from there with the aid of
instrument cluster wiring diagram
- Feb 2009
- 1
February 24th, 2009 02:34 PM #3
high idle RPM at engine start
