Very frustrated with my second starter motor burn-out
Vehicle is a Ford Everest. First burn was due to the defective solenoid (OEM starter). Got a replacement type and all is fine again.
Then after 2 months it burned again, this time it's due to the ignition daw not cutting the relay signal to the starter to switch if off hence the cause of the motor burn-out.
I'm putting this repair on hold before I burn another 10k peso starter. Much appreciate it if you can give some inputs.
Thanks!
