Results 1 to 10 of 11
July 26th, 2018 10:21 PM #1
Hello guys, yung sportage namin may problema. Yung door sa likod ng driver eh nag malfunction yung power door locks niya.
After once or twice mong mag unlock/lock, ayaw ng mag function. It gets weaker and weaker until hindi na gumagalaw yung door locks. Kelangan manual na.
After a while, maybe 10mins, function ulit siya for once or twice then ayaw nanaman.
Any idea whats wrong?
July 26th, 2018 10:33 PM #3
You can try to check the actuator, the one responsible for the lock.
You need to remove the entire cover of your door to access this thing. Once removed, you dismantle the actuator and check it by giving a 12 V DC supply to see if it is functioning properly. Otherwise, some mechanical connections could be loosed.
- Apr 2008
- 6,237
July 26th, 2018 11:16 PM #4Replace actuator. It seems na sakit talaga ito ng lahat ng Hyundai/Kia. Napakaaga bumigay ang power locks. Lahat ng Korean cars na dumaan sa amin napapaltan to. In contrast, bukod sa tailgate, our 21y/o Japan surplus Granvia still has its original actuators. IIRC, generic China replacement costs 450 each. Not sure if surplus is available for Hyundai/Kia, but casa is bound to be expensive.
Sent from my SM-G900I using Tapatalk
July 27th, 2018 12:39 AM #5
actually napansin ko rin yan sa sorento namin 2009. napalitan na lahat ng actuator kasi nasusunog sila ng bigla. tumitigas yung lock. madaling palitan yung actuator ng sorento kasi parang conventional type eh. unlike sa sportage parang assembly siya sa mismong latch ng door
pero kakaiba sa sportage namin. initially ok yung lock sa likod pero after two lock and unlocks tsaka ayaw mag respond nung lock sa likod ng driver. parang tumataas ang resistance ng actuator after 2 cycles.
mahal pa naman ang original nito sa casa
- Apr 2008
- 6,237
July 27th, 2018 12:47 AM #6"Pagod" na siguro ang actuators. [emoji23] Banawe boys (or Araneta boys in my case) are very good though. They will gripe about how hard it is for this model but will still finish the job anyway.
Our 2010 Carnival has the same problem. I think all door lock actuators have been replaced by now. Likewise with a relative's 2011 Carnival. And theirs started happening when the vehicle was just 3 years old!
- Sep 2013
- 56
August 2nd, 2018 11:36 PM #7My 1st gen sportage's original actuators all gave up. I replaced them all with generic actuators. Yung driver side actuators lang yung iba ang connections from OEM to generic
Sent from my SM-N920S using Tapatalk
August 3rd, 2018 12:23 AM #8
Yung kulay blue bayan or black na generic actuator? Nagkakaroon ng problema yan sa sorento ko. It keeps on unlocking 10 times in a row when I turn off the engine or open the driver's door. Parang may wire na hindi naikabit ng mekaniko. Hindi madetect ng sorento ko na unlocked na yung door kaya paulit2x nyang unlock unlock lahat ng pintuan
Sent from my SM-A605G using Tapatalk
- Sep 2013
- 56
August 3rd, 2018 02:04 AM #9Kulay black. The problem might be in the wiring of the driver's door. Other doors have only one connector. The driver's door have I think two connectors, one for the actual movement of the actuator and the other for the door lock sensor.
August 3rd, 2018 03:21 PM #10
Do you have any idea saan dapat iconnect yung wire ng door sensor? I plan to DIY nalang since nabubuksan ko naman yung door panel. Di ko lang mahanap yung wire ng sensor
The serpentine belt is still okay, usual consumables (air filter, oifl filter, cabin filter) got...
Ford Everest 2015
