Results 1 to 8 of 8
    Apr 2018
    Hello po. Ask ko lang po kung san ikakabit yung green wire?
    Toyota corolla lovelife 2e engine po oto di ko po kasi mapagana. Thank you po sa sasagot
    Feb 2009
    What engine management system do you have?
    What type of ignition?
    IIA?
    Coil on plug?
    Apr 2018
    IIA?
    Coil on plug?
    How would I know the answer to those questions? Hehe i'm newbie please help
    I have the same engine bay (photo taken from google)
    Feb 2009
    Yours is IIA (integrated ignition assembly).
    There is a single wire connector hanging unconnected, that is the tachometer signal output connected straight to the (--) terminal of the ignition coil.
    Or
    On the TDCL (Toyota diagnostic link), there is IGN (---) terminal that you can use
    Apr 2018
    Or
    Hopefully I can find that unconnected wire! Please bear with me.
    Where is the tdcl?
    Feb 2009
    My apologies.
    It is a loose wire that is capped usually green next to the distributor connector
    Apr 2018
    My apologies.
    There is no loose wire capped with green next to the distributor connector. **** i dunno if i'm doing this wrong or it's just not there..
    Apr 2018
    Quote Originally Posted by Jhnlsm View Post
    Finally got it to work. Thanks to mr *jick.cejoco
Tachometer install
