Hello po. Ask ko lang po kung san ikakabit yung green wire?
Toyota corolla lovelife 2e engine po oto di ko po kasi mapagana. Thank you po sa sasagot
What engine management system do you have?
What type of ignition?
IIA?
Coil on plug?
Yours is IIA (integrated ignition assembly).
There is a single wire connector hanging unconnected, that is the tachometer signal output connected straight to the (--) terminal of the ignition coil.
Or
On the TDCL (Toyota diagnostic link), there is IGN (---) terminal that you can use
Hopefully I can find that unconnected wire! Please bear with me.
My apologies.
It is a loose wire that is capped usually green next to the distributor connector
