Results 1 to 6 of 6
- Apr 2012
- 80
October 9th, 2013 09:51 AM #1Hi Tsikoteers, I have this keyless entry remote that keeps on locking the car even if it is not touched. It keeps on pressing the Lock switch I guess. The blue tiny LED (indicator when a button is pressed) keeps on blinking whenever the remote battery is there. I don't think it is caused by a stuck tact switch button because I could still hear the switch click whenever I press it and unclick whenever i release it so I think there is something shorted. Anyone experienced this already? Meron po bang simple remedies dito aside from replacing the whole alarm system? I pretty much have knowledge in electronics engineering so if you have troubleshooting suggestions on what I should check then I think I could take a look over it.
Thank you po.
:D
October 9th, 2013 10:09 AM #2
October 9th, 2013 06:01 PM #3
interim till it gets fixed: keep your car keys separate from the remote. keep your remote in your sinturero along with your house keys etc. when your car keys is in your ignition.
October 11th, 2013 09:05 AM #4
October 11th, 2013 10:36 AM #5
Happened to me last last week. Naka-ilaw lang yung remote led tapos lock ng lock. Yung sa akin naman, lumubog yung switch na parang nawala yung spring. Sa tingin ko ang nagyari sayo is grounded lang yung switch. Ginawa ko, kinuha ko yung switch sa sirang spare remote tapos un ung ipinalit ko. DIY lang na basic soldering skills ang kailangan.
Worse case, go to your supplier and then ask for a replacement of remote. Usually ipo-program lang nila yung bago para sa existing car alarm/keyless entry ng auto mo.
- Apr 2012
- 80
October 11th, 2013 11:21 PM #6thanks for the suggestions, desoldered the tact switch (Solder Mount Type) and replaced it with an almost identical tact switch (Trough Hole Type nakuha ko sa office hehe) but bent the pins and cut them in smaller sizes so they could fit, soldered and done! :D
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
