Results 1 to 8 of 8
- Oct 2006
- 128
October 30th, 2006 01:51 AM #1if u have a car which has no powerlocks, no power windows using keys, very manual, id like to modify it a litttle bit with power locks (is it pre requisite in putting a car alarm which i am also thinking of putting), what will i put or choose to put, and re keyless entry (what do u think of this, is it ok or is it better if i just put car alarm instead because it also includes keyless remote entry) and what will i put.
* i have a 3 door hatchback, cvic
usually how, and how much will it cost.. where to buy and have it installed, and how long..
either
a. powerlocks and keyless remote entry combo
b. powerlocks and car alarm combo
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 31st, 2006 03:01 PM #2Pwede yung plano mo. Don't know how much power windows cost but we installed one on our old 1990 sentra. Just check sa mga car accesory shops.
For alarm and power locks, available din yan sa mga car accesory shops. The following links might help. For mr I'll get an alarm with power locks for convience.
http://tsikot.yehey.com/forums/showt...ght=power+lock
http://tsikot.yehey.com/forums/showt...ighlight=alarm
use the search function dami mga threads na related.
October 31st, 2006 03:11 PM #3
Central locking for a sedan is typically Php1,500. That's a four door set up already. I'm expecting two doors to be less expensive.
The keyless entry/alarm/anti-theft system will cost around Php1,900. That would be a Cobra, Venom, Police or other Taiwan brand system.
The price of a keyless entry vs. that of a full anti-theft system (car alarm with ignition kill) is not that far off. I suggest just get an alarm. It has a switch in case you want it to function only as a keyless entry system while still being able to offer vehicle protection when in anti-theft mode.
October 31st, 2006 03:20 PM #4
perhaps, get a reputable car alarm system. then if you want, you could simply disable the alarm sound but keeping the ignition kill mode.
October 31st, 2006 03:32 PM #5
On older Cobra systems you can change over from keyless entry to anti-theft just by punching the right combinations on the remote.
On the newer model we got, this is no longer possible. You have to physically flip the switch hidden under the dash with the key in the 'ON' position.
October 31st, 2006 09:04 PM #6
power windows for a hatch is around 3k to 4k. you'll need to change your sidings as well if you're getting JDM (japanese) power windows.
also, you'll need to buy actuators if you want to put power locks since mano-mano ang hatch locks. consider that as well if you're getting a keyless entry system.
November 10th, 2006 12:56 AM #7
meron po ba sa market na package na ang powerlocks with keyless entry system? yung kahit wala ng alarm. Salamat po!
November 10th, 2006 12:59 AM #8
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
