Results 1 to 10 of 14
- Dec 2013
- 22
March 24th, 2014 09:06 PM #1good evening po, my ride is a 1991 Toyota Corolla XL4 with a 2E engine, napansin ko lately na pag naka on lahat ng accesories ko HL, a/c, etc. sobrang nanginginig makina, and napapansin ko din pag tumatapak ako sa brakes ng madiin nginig din makina ko (bumababa rpm from 900 to 700) anu kaya culprit dito?
BTW:
naka BG 3rd brake lights ako
nagpalit na ko ng alternator ko almost 5 years ago from stock 40 amps to 90 amps.
- Oct 2009
- 2,271
- Jul 2006
- 61
- Dec 2013
- 22
March 26th, 2014 11:20 AM #4salamat po sa replies, can you recommend any good alternator/electrical shops dito sa Paranaque, Las Pinas area?
March 26th, 2014 11:27 AM #5
Kumuha ka ng voltmeter. Tingnan mo kung bumababa ang voltage pag on mo ng mga accessories.
- Jul 2011
- 1,711
March 26th, 2014 11:31 AM #6
- Dec 2013
- 22
March 30th, 2014 06:44 AM #7update lang, pina check ko alternator ko with all amenities open nasa 13.5 v ang reading nya...nginig pa din, kaya tinaasan na lang namin yun idle up ng a/c..my oh my anu kaya eto?
would a big three wiring upgrade solve this?
March 30th, 2014 07:53 AM #8
imho, there is nothing wrong with the alternator. walang kinalaman yan sa nginig. palagay ko, sira ang aircon actuator mo. kindly check your actuator. bali dalawa po yan, its either of the 2 ang maaring sira. isa po nyan, nasa throttle body area (carb/efi), vacuum selonoid po yon sir. hihilain paatas ang rpm pag naka engage ang aircon. ang isa non, yong aircon actuator na connected sa compressor ng sasakyan natin. hope this helps. pwede po ninyo i DIY yon.
- Dec 2013
- 22
March 30th, 2014 09:05 AM #9tumataas naman po yung idle ko pag naka on ang a/c, pero will still check on this, salamat
- Dec 2013
- 22
March 30th, 2014 09:09 AM #10900 no a/c, 1000 with a/c... anything below 900 nanginginig na makina kaya di ko na binabaan
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
