Haha..
Jumper cable, Ammeter, Voltmeter
Marunong kaya gumamit si Cath nyan.
Eto pa how to test parasitic draw.. She needs to learn how to read 50 Milliamps.
Haha..
Yung baterya ng fortuner nung kaibigan ko kanina nadiskarga kasi nakalimutang patayin yung foglamps. Ang ginawa ko bumili ako ng jumper cable 400 amp at nung pinagkabit ko na ayaw pa rin magstart. Napansin ko rin na uminit yung clamp ng jumper. Kaya kinadyot na lang namin. Ano kaya naging problema nung jinumper ko?
Last edited by uls; July 16th, 2013 at 11:44 PM. Reason: rearrange words, kung --> kulang
you attempted eight times? a diesel? perhaps your glow plugs weren't hot enough because the battery was weak...
vvti? in my experience, it's easier to push-start an efi than a carburetted one.. i have a battery charger, but it's still easier to push-start my car than charge the battery..
Knowing na hindi pala gagana ang jumper cable sa diesels. Ano kaya pwedeng kong gawin kung sakaling madiskargahan din ako ng sasakyan? Ibabalik ko na lang to bukas sa hardware store, ipapapalit ko ng ibang item.
Nabasa na nga tapos napahiya pa sa chicks
Sent from my GT-N7100 using Tapatalk 4 Beta
sariling gawa cables namin eh
you can do what 12vdc did. gumawa siya ng sarili jumper cables
http://tsikot.com/forums/electricals...9/index12.html
there is a trick to overheating jumpers, if you have a second set lying around. get 'em and connect 'em in parallel to the one already connected.
Ginawa ko negative to negative umandar naman. Ang galing naman ng Amaron battery![]()
Kapag ba pinatay ko I need to jumper cable again?
