Page 32 of 38 FirstFirst ... 22282930313233343536 ... LastLast
Results 621 to 640 of 754
    #621
    Haha..
    Jumper cable, Ammeter, Voltmeter
    Marunong kaya gumamit si Cath nyan.
    Eto pa how to test parasitic draw.. She needs to learn how to read 50 Milliamps.
    #622
    Yung baterya ng fortuner nung kaibigan ko kanina nadiskarga kasi nakalimutang patayin yung foglamps. Ang ginawa ko bumili ako ng jumper cable 400 amp at nung pinagkabit ko na ayaw pa rin magstart. Napansin ko rin na uminit yung clamp ng jumper. Kaya kinadyot na lang namin. Ano kaya naging problema nung jinumper ko?
    #623
    Quote Originally Posted by beni23 View Post
    gaano ka-init? nahahawakan pa ba nang kumportable? nakaka-paso? may natunaw ba? most jumpers will heat up a little when in use. even your battery cables will heat up a little when in use..
    natural lang uminit ang cable pag nagreredondo
    pero pag mahina or ayaw mag redondo tapos mainit ang cable malamang kulang sa ground
    saan mo nilagay ang negative?
    Last edited by uls; July 16th, 2013 at 11:44 PM. Reason: rearrange words, kung --> kulang
    #625
    pero pag umiinit ang cable mahina or ayaw mag redondo malamang kung sa ground
    Battery to battery. Positive to positive, negative to negative. Naka-start naman yung makina ng sasakyan, everest. Defective kaya yung wire?
    #626
    Nahawakan ko pa naman yung clamp. Natakot lang ako nung uminit. Mga 8 times inistart pero ayaw talaga eh.
    a ok
    diesel kasi yan
    mas malakas demand sa kuryente ang starter
    kaya uminit
    matagal redondo (many cranks) iinit talaga yung cable
    #628
    Naka 8 ka pala. Sakin nung hindi nag start tinanggal ko na
    Sent from my GT-N7100 using Tapatalk 4 Beta
    #629
    you attempted eight times? a diesel? perhaps your glow plugs weren't hot enough because the battery was weak...
    vvti? in my experience, it's easier to push-start an efi than a carburetted one.. i have a battery charger, but it's still easier to push-start my car than charge the battery..
    #630
    Knowing na hindi pala gagana ang jumper cable sa diesels. Ano kaya pwedeng kong gawin kung sakaling madiskargahan din ako ng sasakyan? Ibabalik ko na lang to bukas sa hardware store, ipapapalit ko ng ibang item.
    so nagreredondo but the engine wont come alive
    hirap ba mag redondo?
    pag hirap magredondo either mahina ang source battery or your cables are too thin
    no wait... pwede mag jumper ng diesel
    we jumper diesels all the time
    basta siguradohin malakas ang source battery
    and we use really thick cables coz starters of diesel engines demand a lot of current
    #633
    mabilis ba ang redondo o hirap?
    Hirap pa rin siya magredondo. 3 years na rin tong batt ng eve ko. At manipis nga tong nabili kong cable, pero ang nakalagay 400 amps. Tsk. Sayang lang effort at pera, umaambon pa naman kanina at nabasa pa ako.
    #634
    Magrecommend ka naman ng store at brand ng cables na pwede kong bilhin para ready na ko next time. Chicks pa naman yung friend ko na yun, medyo napahiya ako eh. Hahaha
    #635
    Nabasa na nga tapos napahiya pa sa chicks
    #636
    100% agree dito, i also use 2 8D's when jumpering our 1500kw caterpillar diesel generator set.
    sariling gawa cables namin eh
    you can do what 12vdc did. gumawa siya ng sarili jumper cables
    http://tsikot.com/forums/electricals...9/index12.html
    #638
    there is a trick to overheating jumpers, if you have a second set lying around. get 'em and connect 'em in parallel to the one already connected.
    ^^^ ya share load
    #640
    Ginawa ko negative to negative umandar naman. Ang galing naman ng Amaron battery
    Kapag ba pinatay ko I need to jumper cable again?
How to Know If It Is Only A Battery Problem
