Results 1 to 20 of 30
Threaded View
    Quote Originally Posted by Liana View Post
    Hello po ulit, Sensya na po if madaming issue na naitatanong..
    Ano po ang problem if cold start ayaw mag start agad? Nakakarinig lang ako ng isang click sa first attempt. Then on the second attempt, mag start naman xa agad?
    Nag try din po ako na patayin then wait for 2-3 hours then start, okay naman na.. All lights are good, stereo, aircon are also working.
    Kahapon lang po nag start na 1 click sa first attempt then starts sa second, tapos ngayon na ulit nanaman kanina..
    Ano po kaya problem and need paayos or palitan? Thanks in advance po as always..
    My car is a 2010 Honda Civic AT
    i re-read your post again, and...
    yikes!
    i mis-understood!
    re-reading it again...
    i think that's your starter solenoid, po.
    have someone see it. if i am correct, it will only get worse.
    one day, you won't be able to start your car anymore. ... not even if you replaced your battery.
    it's sometimes difficult to diagnose starter solenoid problem, because they are initially intermittent...
Help, It won't start on the first click!
