Results 1 to 10 of 30
- May 2019
- 54
November 14th, 2020 09:08 PM #1Hello po ulit, Sensya na po if madaming issue na naitatanong..
Ano po ang problem if cold start ayaw mag start agad? Nakakarinig lang ako ng isang click sa first attempt. Then on the second attempt, mag start naman xa agad?
Nag try din po ako na patayin then wait for 2-3 hours then start, okay naman na.. All lights are good, stereo, aircon are also working.
Kahapon lang po nag start na 1 click sa first attempt then starts sa second, tapos ngayon na ulit nanaman kanina..
Ano po kaya problem and need paayos or palitan? Thanks in advance po as always..
My car is a 2010 Honda Civic AT
November 14th, 2020 09:13 PM #2
if its clicking then the ignition assembly is fine
it could just be the aging battery? how old is it?
- Jan 2018
- 844
November 14th, 2020 09:21 PM #3How old is the battery? You might just need a new one.
- May 2019
- 54
November 14th, 2020 09:35 PM #4Hello po sir Stock, Thanks as always.. 2 years na po, motolite gold. And i forgot to mention na may naiwan akong isang ilaw sa loob na nakaopen for about 2 days, because of the typhoon di ko man lang nacheck yung car... and kahapon pag open ko ng first attempt nag one click lang xa, and then at the second attempt, nag start ng maayos and naka-open pala yung ilaw.. Is it 100% battery na po ba talaga?
2 Years na po yung battery, motolite gold 2018 po xa nabili.
November 14th, 2020 09:41 PM #5
November 14th, 2020 09:42 PM #6
November 14th, 2020 09:46 PM #7
Hmm 2yr old Motolite Gold...That's about the end if you weren't conditioning it on a trickle charger. I can't recall a dead battery giving me intermittent starts, tho. It usually shows signs like weak cranking to just clicking. Never dead now, alive on 2nd try. Have batt, its terminals, ground connections & the brake switch checked. Eliminate the suspects before you go replacing stuff.
November 14th, 2020 09:55 PM #8
Motolite Gold only has 21-month warranty and Motolite batteries typically conk out after its warranty expires. Just replace it.
- 52,698
November 14th, 2020 10:01 PM #9"battery."
also, tighten the battery terminals.
some battery stores have a battery checker service for free.
have it checked.
if the reading suggests replacement, have it replaced already.
nothing can be more panick-y than a dead battery in an otomatic car, kung kelan ka pa nagmamadali.
good luck.
- May 2019
- 54
November 14th, 2020 10:23 PM #10Hello po doc! Actually last 2 weeks ago, nag pacheck kami ng pinsan ko sa 2 motolite shops, yung first check pina-start then umabot sa gitna nung gauge ung arrow nung tester and said na need na i-replace, then pumunta kami sa isa pang motolite shop then tinest, okay pa naman daw. Kaya sabi ng pinsan ko, chcheck nia yung ilalim para linisin ung starter baka dun lng daw kasi minsan parang nahihirapan mag start yung engine, parang naghahabol ng hinga before mag start (often happens after ng byahe).
But anyway, magpapalit na po ako this week ng battery. Ayoko din po talagang huminto sa gitna ng byahe thank you po.
My thoughts: Resale value is really about perception, and right now the perception is that a...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
