Results 1 to 10 of 11
- 34
September 21st, 2004 11:38 PM #1Please help!
My ride is an A/T 93 corolla Gli. I noticed that my battery warning/indicator lights up(and then quickly goes back to normal) when I shift from Drive to Reverse. Any idea why this happens? By the way the battery is new.
- 34
September 22nd, 2004 11:02 PM #4mga ser, okay naman ang alternator belts and alternator, terminals okay din.
I noticed this afternoon that when I shifted from Park to Reverse the battery indicator also went on and then off.
September 23rd, 2004 12:01 AM #5
Di naman po kaya nagpalit kayo ng higher wattage bulbs sa reverse light assembly?
Try to think back what was the last modification you've done, or adjusted a bolt that could have loosen a ground wire.
- 34
September 23rd, 2004 08:54 PM #7
try to switch-on all electrical components..the lights..hi-beam, interior lights, full blast aircon, defogger, radio, signal light, brake light, wiper, etc..
then switch to reverse, naka-on pa rin po ba battery light?
baka po meron grounded somewhere sa car ninyo..
September 23rd, 2004 11:20 PM #8
If you are not having problems with your electrical system (discharged palagi, etc.), baka minor electrical fluke lang yan.
Observe mo lang.
- 34
September 25th, 2004 10:01 PM #9revoGSX, thanks for the suggestion, I tried lahat 'yung sinabi mo except for the wiper pero hindi naman nag on 'yung battery warning/indicator.
OTEP, wala namang electrical problems so far.
Additional info, I noticed that when I shift real slow from Drive to Reverse, the battery warning/indicator is less likely to light up.
September 25th, 2004 11:31 PM #10
nangyari na sa akin yan, except yun o/d lights ang nag-bli-blink... turns out yung battery malapit na masira. nung pinalitan ko, ayos na.
Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage Jay...
2023 Toyota GR Corolla Hatchback
