Results 1 to 10 of 10
- Mar 2009
- 3
January 22nd, 2010 03:46 PM #1Hi, i just installed a pair of LED brakelights for my 2002 Mitsu GSR. Now, after 10 min of driving, my ABS sensor always starts to turn on. I know someone who experienced the same thing. i was thinking since LED's consume less electricity, the ABS is unable to detect the presence of the brake lights. Is there a way to rewire or at least "fool" the system? will appreciate your inputs
THE AUTO SPECIALIST
- Mar 2006
- 607
January 23rd, 2010 03:13 AM #3
- Jan 2010
- 1
- Jul 2009
- 3,604
January 23rd, 2010 11:47 AM #5Did you disconnect the battery while installing the brakelights? Something may have shorted during installation.
- Mar 2009
- 3
January 23rd, 2010 01:23 PM #6
January 23rd, 2010 03:53 PM #7
The system senses if any of your stop lamps are busted. If the circuit is open (ie. busted bulb or the bulbs are disconnected), the ABS warning indicator lights up. It does so by measuring the current drawn by the bulbs. Stock filament bulbs are either 21W or 25W usually. Compared to the stock bulbs, LEDs have very small power requirements, most likely not enough for the system to sense their presence. That's why the system thinks that the bulb is either busted or missing, hence the ABS warning.
- Mar 2009
- 3
January 25th, 2010 12:53 PM #8
January 31st, 2010 01:02 AM #9
Almost same as your probs: http://www.plasmaled.com/tail_light_led_bulb_fix.htm
January 31st, 2010 01:10 AM #10
For DIY:
http://cbrworld.net/forums/thread/141166.aspx
If you find resistor like this here for easy installation:
http://www.v-leds.com/BlinkerWarning...-p4783296.html
and
http://www.motovationusa.com/mvstore...?idproduct=500Last edited by xda2jojo; January 31st, 2010 at 01:31 AM.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
