Results 41 to 49 of 49
- Jun 2005
- 3,774
July 4th, 2017 01:22 PM #41The stock h4 bulb is already halogen. Baka they mean getting higher wattage bulb. Delikado sa wiring yan. Malulusaw socket mo. Need to upgrade to ceramic.
About selling the old bulb, no one will buy that. Either keep it as spare or trow it away. 150 pesos lang bagong bulb sa autosupply.
July 4th, 2017 01:42 PM #42
*queenmj
could it be that your headlights lens are blurry/naninilaw? you have to address that also before you upgrade your bulbs or it would be worthless.
mag night breaker or xtreme vision ka na lang para stock wattage pa rin.
- Jul 2017
- 12
July 4th, 2017 08:14 PM #43
- Aug 2012
- 2,767
July 5th, 2017 12:07 AM #44
- Aug 2012
- 2,767
July 5th, 2017 12:12 AM #45
- Aug 2012
- 2,767
July 5th, 2017 12:14 AM #46Clean your headlight lens and then go get yourself Philips Xtreme Vision +130% H4 bulbs. Stock wattage and just plug & play.
Sent from my ASUS_Z010D using Tapatalk
- May 2011
- 481
July 5th, 2017 09:43 AM #47If your situation for low visibility is that your headlight lenses are oxidized or hazed, clean or replace the headlight assembly. This problem was not a concern when cars used sealed beam headlights with glass lenses. There is a limit as to how bright your lights are without inconveniencing the oncoming driver. If your situation is that you have inadequate night vision, use driving glasses to be able to see better. Don't be a dick to other drivers on the road. Share the roads, they are not yours nor it is your right to drive. The reason driver's license are issued is because it is a privilege, not a right. Otherwise, in the same token, if breathing was a privilege, you'd be required a license to breathe.
- Jul 2017
- 12
July 5th, 2017 10:48 AM #49Yes, when i check my headlights, medyo hazed na nga siya. Our car parked inside our house kaya medyo protected sya and for 19 years, malabo lang siya not like the others that yellow na talaga and you almost can't see the bulb.
I also experienced some drivers na naka bright sila and sometimes di nga masyado maliwanag pero yung luminance nya masakit sa mata.
Will try to clean it first.
thanks
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
