Results 1 to 10 of 49
- Apr 2009
- 272
January 25th, 2017 02:27 PM #1Based on my cars manual it says required wattage for headlight is 55w but i installed it with a 95w osram headlight. Will this damage my battery or alternator?
- Jan 2017
- 8
- Oct 2009
- 2,271
January 25th, 2017 02:30 PM #3
- Jan 2017
- 8
January 25th, 2017 02:33 PM #4
- Oct 2009
- 2,271
January 25th, 2017 02:34 PM #5
January 25th, 2017 02:38 PM #6
January 25th, 2017 02:50 PM #7
I believe that for halogen or conventional filament bulbs, anything above 60W is considered off-road use only.
- Mar 2017
- 10
March 21st, 2017 05:04 PM #8Siguro pag 3 to 4 hrs naka-on yun lights mo eh ok lang. pro pag may long drive ka at naka-on for say 5 to 6 hrs delekado. Ganun din ginawa ko sa ilaw ng tsikot ko dti nalusaw yun kabitan ng bulb. Maybe depends din siguro sa car. Luma na kasi yun car ko kaya baka marupok na rin siguro yun mga plastic lagayan ng bulb.
Maisingit ko na rin. Anyone may experience sa led headlight bulb? Alam ko maliwanag sya pero kamusta naman ang throw ng liwanag? malayo din ba?
March 26th, 2017 05:04 PM #9
Higher wattage will draw more current, more current require bigger wires in terms of diameter
Fail to do so could melt the insulation of your stock wire for that light you just replaced with higher wattage
The ensuing event is the unthinkable a full blown conflagration because your wires will be exposed and touch each other and short the circuit
Next thing you will need is a fire extinguisher
Sent from my GT-P3110 using Tsikot Forums mobile app
- Mar 2004
- 434
March 26th, 2017 05:11 PM #10
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
