Sorry, I was thinking about speaker wires while typing that. Naisulat ko pa "the perfect speaker"
However, the premise still remains the same. After all, the greatest attribute that affects impedence is resistance. In that case, impedence is result of resistance.
When I look into car audio installations (trust me, I've seen a lot), you won't see them doing multiple grounding points. The reason for this is a matter of saving themselves headaches. The more grounding points you do, the more chances of encountering a ground loop after all. If you can just do a single ground, why the hell do you need multiple ones? I mean, if you have multiple grounding points and you're experiencing a voltage drop, you'll be checking each and every one of them versus just checking once on a single grounding point. Why go through all of the hassle?
I don't see the need for efficient distribution. Electrons in wires travel something like 300,000 kilometers per second.
As long as it can get from Point A to B with the least resistance, okay na yun.
Between multiple 8AWG versus a single 1AWG, it won't matter. It's just that I don't know why people would spend for MORE when there's less. You're spending more for plastic sleevings on the wires, the labor of grounding it, the brand name of HKS, and the circle gold plated stuff that does nothing except be more eye candy. In that case, you're better off getting a larger diameter wire and dressing it up on techflex of your choice. Less expensive, more protection, and less engine bay clutter.
It's like if Jollibee is offering you 100g ChickenJoy Breasts for 100 pesos versus 100g ChickenJoy Wings for 200 pesos. It's the same chicken down to the last gram... and given that you have no special preference on chicken parts, why would you choose the more expensive one and the more tedious one?
