And remember grounding wires/battery/alternator are DC system so you cannot compare to a speaker which is an AC system, hence resistance is not impedance. Speakers will always have impedance because of the coils, you cannot make near-zero ohm to move a coil around a magnet.
Grounding kits helps in distributing the current flow thru multiple grounding contacts. Considering that most auto wires are just designed to run basic electrical accessories and they degrade over time(crimps, bonds,corossion, torque), installation of additional grounding would always be an advantage.
Imagine one thick wire with single contact vs multiple thin wire in multiple contact. You should be comparing firehose to a multiple garden hose.
