Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 221 to 240 of 241
    Aug 2012
    #221
    lalakas po ba charging pag gumamit ng grounding kits? at hindi na ba maglolobat
    Nov 2012
    #222
    magkano na po ba set ng grounding kit ngaun sa blade
    Aug 2010
    #223
    Why do you want a grounding kit when there's the Big Three electrical upgrade? *scratches head*
    #224
    pls. help nmn po... how to install hks grounding kit? vti96 po car ko. thanks!
    Feb 2014
    #225
    Saan po meron magaling na mag install o gumagawa ng grounding kits near cavite or makati or manila area? Car ko po is honda city 97 AT, thanks
    Posted via Tsikot Mobile App
    Aug 2006
    #226
    Quote Originally Posted by ronskiee View Post
    Meron po akong open thread about that sir ronskiee Shops that can do grounding kit installation in cavite area?. But up to now naghahanap pa din ako ng reliable shop who knows the proper procs of grounding kit installation at malinis mag-wiring :-)
    If by chance may makita kang shop in bacoor/imus area na mag-iinstall ng grounding kit mo, paki-share naman kung saan. Thanks
    Feb 2014
    #227
    si azkal nga maganda yung DIY nya dba, mga ganun sana e. kaso hirap humanap ng ganun sa mga shop, sige boss inform kita if ever may makita ako. inform mo din ako pag may makita ka din.
    Feb 2014
    #228
    manginig kasi yung auto ko, parang hindi stable ang bato ng kuryente. baka makabawas ng panginginig yung grounding kit.
    Oct 2009
    #229
    Kahit lagyan mo yan ng grounding kit manginginig pa rin yan. Pacheck mo muna sa mekaniko kung ano ba talaga ang sira.
    Feb 2014
    #230
    sir baka may alam kayung magaling na mekaniko, yung all around. thanks
    Aug 2006
    #231
    Yes sir, magaling at malinis pagkaka-tira ni boss askals sa grounding kit nya and very detailed ng procedures kaso zero knowledge talaga when it comes to electrical at kulang din sa tools. Since kuryente yan, mahirap isapalaran kung ang gagawa has lack of experience. Anyways, cge sir update kita pag may nahanap akong shop.
    Aug 2012
    #232
    share lang.. 5-point Grounding Kit in our Revo installed in 2012. Battery (-) terminal connected to:
    1. Firewall
    2. Intake Manifold (near EFI marking)
    3. Chassis/Body (Right) [not seen in photo]
    4. Alternator [not seen in photo]
    5. Cylinder Block [not seen in photo]
    old photo taken in 2012..
    Feb 2014
    #233
    Quote Originally Posted by red_one View Post
    1. Firewall
    ganda sir, pwede po magpagawa ng ganyan? honda city 97 po oto ko
    Aug 2012
    #234
    This is the kit that was installed..
    Feb 2014
    #235
    sir pa install naman sau
    Aug 2012
    #236
    *ronskiee: Sa province kami brod eh. Kayang-kaya naman DIY yan basta alam mo location ng parts sa engine bay ng car mo.
    Tool required is an adjustable wrench or a set of wrench for different sizes of bolts.
    Universal grounding kits can be used in any car model. For 5-point grounding kit, choose any 5 ground points. For 6-point grounding kit, choose any 6 ground points. And so on.
    Possible Grounding Points:
    1. Chassis/Body (Right)
    2. Chassis/Body (Left)
    3. Firewall/Bulk Head
    4. Intake Manifold
    5. Alternator
    6. Cylinder Head
    7. Cylinder Block/Engine Block
    8. Valve Cover
    9. Starter
    10. Transmission
    11. Distributor
    12. Aircon Compressor
    If the included wires are long, connect each wire directly from the battery to the ground points. Example,
    1. Battery (-) terminal to Chassis/Body
    2. Battery (-) terminal to Intake Manifold
    3. Battery (-) terminal to Firewall
    Etc.
    If some wires are short, you can daisy-chain ground points that are near each other. Example,
    2. Chassis/Body to Intake Manifold
    3. Intake Manifold to Firewall
    Etc.
    For safety, remove the connection of Battery (+) terminal before installing ground wires.
    Make sure all connections are tight.
    To keep things tidy, use plenty of cable/zip ties.
    Keep the wires away from moving parts and hot engine parts.
    After completing the installation, return the connection of Battery (+) terminal.
    Aug 2006
    #237
    Sir, magkano kuha nyo sa Divot grounding kit nyo? And makapal po ba wire nya sa loob?
    Aug 2010
    #238
    You do know that you don't really need that many wires.
    Just do the Big Three. It does what a grounding kit does with less wires.
    Get bigger wires. This reduces the electrical resistance needed for current to flow.
    Aug 2012
    #239
    sa HK ko binili in 2012. "PIVOT IGNITION EARTH JAPAN" ang markings sa wires nya. i know someone in HK so i can help you guys buy it if wala locally. i just need to check the price.
    IGNITION EARTH "IE-1" | PIVOT
    Aug 2006
    #240
    Ok sir, paki-update na lang kami kung magkano. Thanks
grounding kits
