Results 1 to 10 of 10
September 29th, 2014 09:21 PM #1
magandang araw sa inyo mga tsikoteers....
arfter 2 weeks na hindi tumakbo sa daan (pinaandar lang sa garahe 2x a week), kinargahan ko ng P500 (approx 10 liters diesel fuel).
nung pagkakarga ko, as usual naman yung level sa gauge nung amount na kinarga. after some km. ayun naginarte na, nagpunta yung needle below E. akala ko tumatakbong gripo na sa daan yung sasakyan ko. false alarm. kung minsan may magreregister sa gauge, minsan as in wala...
tinatamad pa naman ako magkutingting. botohan na lang tayo lalo na yung nakaexperience neto. yung meter/dash gage or yung sending unit? assume nyo na lang ok ang wiring ko.
September 29th, 2014 09:33 PM #2
Nakalimutan mo bangittin floater sa loob ng fuel tank
Sent from my Windows Phone 8 using Tapatalk
September 29th, 2014 09:53 PM #3
September 29th, 2014 10:10 PM #4
Same sentiment pag nagloloko guage 80% of the time yan ang cause
- Jun 2011
- 134
- Mar 2010
- 2,259
September 30th, 2014 12:27 PM #6
September 30th, 2014 01:45 PM #7
mighty max yung sasakyan...parehas lang sa L200 ang parts....
ang problema ko ngayon e wala ako makitang replacement. Pang L300 halos ang meron. hindi rin swak yung mounting. 3 holes yung original e 5 holes yung available. hay buhay................
i'll try to lubricate muna yung sensing part baka maayos pa. seldom lang kasi nafufull tank. from 1/4 to 1/2 lang yung kinakarga ko na fuel.
- Oct 2009
- 2,271
September 30th, 2014 04:15 PM #8common problem sa mga palaging uhaw ang tangke.nasisira ang sender..malamng naputol na ang carbon ng sender
October 8th, 2014 09:14 PM #9
- Nov 2009
- 3,484
October 8th, 2014 10:24 PM #10Earth/Body grounding problem?
Common sa old cars yung failing contacts sa meter cluster and sa return path ng sending unit.
Clean contacts and connectors first.
If you think about it, if the price of the battery does not go down, replacing the battery of a...
Mitsubishi Xforce
