Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    May 2019
    Hello po ulit, Sensya na po if madaming issue na naitatanong..
    Ano po ang problem if cold start ayaw mag start agad? Nakakarinig lang ako ng isang click sa first attempt. Then on the second attempt, mag start naman xa agad?
    Nag try din po ako na patayin then wait for 2-3 hours then start, okay naman na.. All lights are good, stereo, aircon are also working.
    Kahapon lang po nag start na 1 click sa first attempt then starts sa second, tapos ngayon na ulit nanaman kanina..
    Ano po kaya problem and need paayos or palitan? Thanks in advance po as always..
    My car is a 2010 Honda Civic AT
    if its clicking then the ignition assembly is fine
    it could just be the aging battery? how old is it?
    May 2019
    Hello po sir Stock, Thanks as always.. 2 years na po, motolite gold. And i forgot to mention na may naiwan akong isang ilaw sa loob na nakaopen for about 2 days, because of the typhoon di ko man lang nacheck yung car... and kahapon pag open ko ng first attempt nag one click lang xa, and then at the second attempt, nag start ng maayos and naka-open pala yung ilaw.. Is it 100% battery na po ba talaga?
    Quote Originally Posted by SpinCycle View Post
    How old is the battery? You might just need a new one.
    2 Years na po yung battery, motolite gold 2018 po xa nabili.
    Quote Originally Posted by Liana View Post
    It got discharged lng pala. Some shops perform battery tests naman. You can do that or keep motolites or amarons number handy. They do deliver and change batteries on-site.
    Hmm 2yr old Motolite Gold...That's about the end if you weren't conditioning it on a trickle charger. I can't recall a dead battery giving me intermittent starts, tho. It usually shows signs like weak cranking to just clicking. Never dead now, alive on 2nd try. Have batt, its terminals, ground connections & the brake switch checked. Eliminate the suspects before you go replacing stuff.
    Jan 2018
    A/T right? Mysterious intermittent starts? Have the brake switch checked.
    Motolite Gold only has 21-month warranty and Motolite batteries typically conk out after its warranty expires. Just replace it.
    "battery."
    also, tighten the battery terminals.
    some battery stores have a battery checker service for free.
    have it checked.
    if the reading suggests replacement, have it replaced already.
    nothing can be more panick-y than a dead battery in an otomatic car, kung kelan ka pa nagmamadali.
    good luck.
    May 2019
    "battery."
    have it checked.
    good luck.
    Hello po doc! Actually last 2 weeks ago, nag pacheck kami ng pinsan ko sa 2 motolite shops, yung first check pina-start then umabot sa gitna nung gauge ung arrow nung tester and said na need na i-replace, then pumunta kami sa isa pang motolite shop then tinest, okay pa naman daw. Kaya sabi ng pinsan ko, chcheck nia yung ilalim para linisin ung starter baka dun lng daw kasi minsan parang nahihirapan mag start yung engine, parang naghahabol ng hinga before mag start (often happens after ng byahe).
    But anyway, magpapalit na po ako this week ng battery. Ayoko din po talagang huminto sa gitna ng byahe thank you po.
    a dead battery will not usually cause the car to stall while driving.
    but it will probably not start anymore, once the engine is turned off.
    i have a colleague.
    she replaces her battery every two years, regardless.
    na-matayan na kasi siya ng battery sa bahay.
    good luck.
    btw,
    when i replace my original battery, i opt for the next smaller size.
    i did not notice shortness of battery life.
    car is stock. no aftermarket electrical toys.
    Jun 2011
    Kung luma na ang sasakyan, possible din na maluwag na ang carbon brush na naka kabit sa starter rotor. Nangyari ito sa 17 year old car dati.
    Depende sa engine temperature minsan kung maluwag na tolerance nito nag loose contact na.
    Jun 2011
    "battery."
    +1 dito. Sabay linis na din battery terminals. Check din wires at grounding papuntang starter.
    i re-read your post again, and...
    yikes!
    i mis-understood!
    re-reading it again...
    i think that's your starter solenoid, po.
    have someone see it. if i am correct, it will only get worse.
    one day, you won't be able to start your car anymore. ... not even if you replaced your battery.
    it's sometimes difficult to diagnose starter solenoid problem, because they are initially intermittent...
    May 2019
    Update lng po, di ako makatulog so triny ko start ngayon, cold engine, nag start naman po no click or crank delay or whatsoever... haays dko na maintindihan tong fd ko . try ko po ulit bukas inde ko oopen ng buong araw.
    Also, naka note na po sa phone ko lahat ng suggestions niyo and ready na ko for tuesday, Thank you po ulit.
    Dec 2009
    Get a voltmeter that can be attached to the cigarette lighter socket
    A car battery contain 6 cells..each cell carry 2.1volts for a total of 12.6volts
    A dead cell will reduce that to 10.5volts and so on and so forth
    When the engine is running the voltage reading of the voltmeter should be => 13.5volts. Otherwise, the alternator is not functioning properly
    If the voltmeter reading is in proper order, then it's not the battery nor the alternator
    Get that tool and it will save you a lot of money and trouble
    this is very similar to what the battery shops do. only, their gadget (a handheld voltmeter from Ace or CDR king, or a big, heavy thing on wheels) is clamped to the battery beside the engine, and not to the cigarette lighter.
    Jan 2008
    pa check mo starter actuator..
    https://www.autoindustriya.com/auto-...oded-cars.html
    Baka yun starter, bilisan mo 30% discount
    order one now!
    before stocks run out...
    seriously,
    i'd chance on a surplus first, or have mine overhauled.
    palitan ang electronics kung kailangan... the rest of the starter is near-bulletproof.
Help, It won't start on the first click!
