Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
    #21
    Won't you need a police report for this? What will the report say?
    "spontaneous combustion". heh heh.
    #22
    kung electrical fire wala naman magagawa na yung garden hose diba? kailangan ata diyan fire extinguisher na para sa oil and fire. important talaga na may fire extinguisher sa sasakyan.
    kahit papano, may benefit naman ang tubig. mababawasan ang kalat ng apoy at ang sira ng sunog.. low voltage naman yan...
    May 2010
    #23
    CLASS E- Electrical fires
    Using CLASS A (water based) Fire Extinguishers or Water will only worsen the situation. Lalo na't malaki na ung apoy.
    Edit:
    I hope he was informed.
    Jan 2011
    #24
    kung minsan, ang pagtitipid, nagpapalaki ng gastusin. ang karamihan din, nag DIY, just for the fun of doing it. iba din kasi ang sense of fulfillment pagkatapos gawin ng 2 oras ang pwede namang gawin ng 15 minuto ng manggagawa at bayaran lang sana ng 100 petot. i fall on the latter. pasok din ako minsan sa kasabihang, over-confidence of the incompetent.
    #25
    i wish the guy would explain what happened.. we're all just guessing here..
    May 2012
    #26
    Everything that burns turns into carbon.
    Carbon is a good conductor.
    Once sunog na, it will short circuit at kung hindi tama ang kabit ng fuse, electrical fire follows.
    That's when DIY becomes Destroy It Yourself.
    sa foglights ko hindi naman DIY, pina install ko sa autoshop kaya lang nagmelt yun plastic na connector nya at nagdikit na ang tanso at plastic. takot nga ako i on :D kaya patay lagi foglights ko
    Sep 2012
    #27
    Quote Originally Posted by rukawa11 View Post
    Eh di i DIY mo tanggalin para mawala worries mo "\('.')/" just kidding hehehehe
    Oct 2009
    #28
    baka hindi nilagyan ng relay at masyadong maliit ung wire na ginamit..saka hindi naka hinang ung mga dugtungan pulupot kamay lang ginawa,,
    resulta..nag iinit ung kuryente,,spark...susunod mag liliyab na,,
    May 2009
    #29
    walang masama sa DIY as long as ginawa ng tama using correct procedures (safety) with the right tools....using genuine parts (or even with cheaper parts).
    #30
    Basta electrical, Tangalin dapat negative sa battery para sure ball wala mag spark.
    Oct 2013
    #31
    Sep 2005
    #32
    Baka IED at hindi LED yung naibili ni Mirage owner.
    Hope he's insured.
    hahahahaha.... baka terrorista ang nag install ng IED....
    #33
    led installation could not spark that kind of fire... why?- cause led consume less electricity hence it could not lead to such
    but according to topgear phil, that photo was due to improper HID installation - much more plausible since hid consumes more electricity and are a heat magnet
    Oct 2008
    #34
    china ballasts may consume more electricity than stated otherwise they usually use 35w or 50w. an hid bulb generates high temps, but not a heat magnet.
    #35
    Tagal na nitong pic na to ha. Last year pa ata. Sa thailand daw to.
    #Retzing
    Jan 2009
    #36
    ^ Thanks!
    It's sometimes really difficult to screen items posted on social networks.
    It does brings up awareness to people who loves to tinker with their cars.... me included... to be mindful of what you're doing.
    Jul 2010
    #37
    Sa DIY ay dapat tama lahat ang rating ng components ilagay mo. Gaya ng foglamp. Hindi pwede yun ordinary fuse holder nabibili sa aiuto supply. Dapat yun high current type or barrel type fuse holder. Dapat ang fuse holder ay naka locate malapit sa source or +Battery. Hindi pwede ilagay malapit sa device or Foglamp.
    Dahil kung nag short ang unprotected side ng wire sa fuse holder ay sunog din yun wire pati na yun kotse mo. Then dapat lagyan ng Relay para maigsi lang na malaking wire gagamitin para sa supply ng Foglamp. Yun ordinary wire na lang para sa On Off switch ng Foglamp.
DIY Gone Terribly Wrong
