Results 1 to 13 of 13
    Jul 2019
    Hi, would like to ask if i should start first start the car then attach the clamps? or attach them first and start later? Sorry total noob here when it comes to car electronics. TIA.
    Mar 2018
    You should attached the clamps first before starting the car. If you're using cigarette lighter port, this may not have enough power to start the car, worse you may overload it.
    Sent from my YAL-L21 using Tsikot Forums mobile app
    Quote Originally Posted by Suzumiya View Post
    errr,
    i do not understand the situation.
    please elborate.
    errr,
    please elborate.
    maybe those jumper cables that plug into the cigarette lighter. i just searched them now haha meron palang ganun.
    pero as mentioned, when jumpstarting, attach the cables correctly first before starting.
    if one clamps on the clamps onto an already-running engine,
    a strong spark might startle you into doing something that you shouldn't do.
    On jump cables, heres what I'd do:
    1. + discharged to + support
    2. - support to - discharged or body ground to body ground.
    This ensures that the battery sensor is not bridged.
    3. Start & fast idle support vehicle
    4. Start discharged car
    5. Before disconnecting jumpers, turn on lights, rear defroster, highest A/C for 10sec to prevent voltage surge
    6. Remove in this order:support ground, discharge ground, support +, discharged +
    sometimes,
    a basic car has its advantages over an intelligent car.
    my car's battery died,
    because i left the ignition on for a few days.
    i recharged it using my small basic car battery charger, so's i can start it and drive to the battery store. the charger's meter initially said i was putting in only 4 amperes.
    i feared the worst, as it's over three years old.
    but it started, after some hesitation.
    the store guy there tested the battery. "ok pa sir. i-skyway nyo lang."
    Resurrection!
    Easter came early to me.
    OT.
    Jul 2019
    Thanks sir, well noted.
    Jul 2019
    Thank you for all your inputs
    What i meant are those 12 V sockets that can be directly clamped to the battery. I bought an Elevo tire Air Pump but it blew the fuse of our Forty's rear 12 V socket, don't wanna blow off the other sockets so I bought a 12 V socket that can be clamped directly to the battery terminals.
    hey!
    that happened to me, too.
    with the ignition at ACC, i plugged my elevo tire inflator into my innova's cigarette lighter socket.
    it also blew my fuse.
    i have no explanation.
    since then, i insert the plug into it, before i turn the key. but only for the inflator. for my electronic gadgets (cellphone charger, etc), i still plug and unplug with wanton abandon, with the car running.
    and in case the fuse blows again, "minarkahan ko na yung fuse, so's i may replace it easily."
    Jan 2009
    I imagine it's an alligator clip to female cig lighter socket, like this...
    That is used to bypass the accessory cig lighter sockets because, as many of you found out, it will likely blow the fuses to kingdom come. The above cable is used so that the accessory can be attached and powered directly from the battery.
    On whether you need the engine running or not depends on how powerful the accessory is and/or how long you plan to use it. Attach the alligator clips with the engine running or not DOES NOT matter. Just do it safely (ie. correct polarity, cables does not snag any moving parts or the alligator clips accidentally detaching and gets sucked in the accessory belt... these sort of common sense).
    Jul 2019
    This is exactly what ordered hahah. Thanks for the input
    Jul 2019
    hey!
    My engine was already running when I plugged it in. Maybe the fuse just can't handle it hahaha, don't wanna blow the others.
Cigarette lighter with battery terminal clamps usage
