Results 11 to 13 of 13
April 1st, 2021 08:35 AM #11
I imagine it's an alligator clip to female cig lighter socket, like this...
That is used to bypass the accessory cig lighter sockets because, as many of you found out, it will likely blow the fuses to kingdom come. The above cable is used so that the accessory can be attached and powered directly from the battery.
On whether you need the engine running or not depends on how powerful the accessory is and/or how long you plan to use it. Attach the alligator clips with the engine running or not DOES NOT matter. Just do it safely (ie. correct polarity, cables does not snag any moving parts or the alligator clips accidentally detaching and gets sucked in the accessory belt... these sort of common sense).
April 1st, 2021 11:39 AM #12
April 1st, 2021 11:42 AM #13
Traffic!
