Results 11 to 13 of 13
June 20th, 2011 07:12 AM #11
google the words: 1.voltage drop testing 2. parastic drain testing . you'll have your answer and the correct procedures to address your problems
- Feb 2010
- 112
July 20th, 2011 07:11 PM #12
- Aug 2006
- 98
July 30th, 2011 08:02 PM #13
Sir ghosthunter, few questions lang po...
1) Pano po ba normally nililinis ang terminals?
2) Liha lang ba ang gagamitin to clean the surface or pwede din ang old toothbrush, etc?
3) Then apply the vaseline sa palibot ng terminals?
Napansin ko lately na mainit ang negative terminal ng battery pati na un wire, baka kasi makuha sa linis ang problema.
Im also having almost the same issue, but good thing hinde naman umaabot sa scenario na namamatay ang makina...the only problem is bumababa ang rpm ng auto pag nakaopen ang headlights Is it contact point, condenser or battery ang problema??. TIA
high idle RPM at engine start
