Results 11 to 13 of 13
August 24th, 2006 04:35 PM #11
Hmmm... maybe it's the distance of the MAF from the engine? Ah... okay, I get it... on some cars, having an open cone filter right in front of the MAF can mess with MAF readings... by using a CAI, he placed it far enough from the MAF that the MAF was able to work properly.
Oops... my bad, the Honda uses a MAP, not a MAF... but the effect is probably similar. Too much air, too close to the sensor, makes the readings irregular.
It's very easy to get shorter intake plenums for Hondas, as Honda B16s can use Type-R or various aftermarket intake plenums... for the Mitsubishi 1.6, tough luck. The best you can do is thermoplastic spacers. Look on outlawengineering.com , but I doubt they'll have your engine.
You can call Nollie (0910) 785-1240 of PitCrew Performance regarding thermoplastic spacers. He doesn't make them, but he can give you the number of the guy who does. But be warned... they're expensive.
August 24th, 2006 04:48 PM #12
If I remember, 1cm yung kapal nun. Or something comparable.
Niky, it makes sense about the MAP sensor and his readings. MAP far from filter = too much air = increased AF ratio. MAP near filter = less air (due to filtration) = decreased AF ratio. Or something like that hehe.
April 16th, 2009 08:56 PM #13
sir niky ask ko lang yung case ko. 98 civic lxi auto ko. kinabitan ko ng fujitsubo legalis na chambered muffler. after ikabit napansin ko na lumakas yung hatak. pero medyo gusto ko pa palakasin yung tunog. may nagsabi saken na patanggal ko daw yung resonator na katapat ng handbrake. yun yung mataba. dalawa kasi yun sabi nung nagtatanggal. may isa pa na mas manipis nauuna dun sa mataba. ang tinanggal ko yung mataba pinalitan lang ng pipe. lumakas yung muffler. ganda nga ng tunog actually e. pero napansin kong nawala yung hatak na na-gain ko before tanggalin yung reso. parang bumalik sa stock yung hatak lalo na pag uphill ang takbo. im planning to re-install my resonator. or kung ipatanggal ko nalang yung isa pang resonator? ano magiging effect nun? or ipabalik ko yung matabang reso at patanggal ko yung maliit na reso? ano naman effect nun? suggestions naman mga sir kasi ang gastos ng trial and error at putol ng putol ng pipes e. salamat and more power to you guys..
high idle RPM at engine start
