year?, make? model? mileage?
check your ground wire to the right tail/brake light. check for corrosion, looseness, broken wire strands ( these primary wires usually have 15 strands of copper). do you have the seven wire system(the brake light is also used as signal-characterized by no amber lens for turn signal)? if it is, check the double filament bulb for improper installation.
