Results 1 to 3 of 3
    Feb 2009
    for some reason...
    when i have my tail lights on and step on the brake, the right tail light goes out and the left brake light lights up...
    and when i have my tail lights off and step on the brake, the brake lights seem to work fine...
    where can i get this checked? will it cost alot? thanks...
    Check brake light wiring.
    Feb 2009
    Quote Originally Posted by aQord View Post
    for some reason...
    year?, make? model? mileage?
    check your ground wire to the right tail/brake light. check for corrosion, looseness, broken wire strands ( these primary wires usually have 15 strands of copper). do you have the seven wire system(the brake light is also used as signal-characterized by no amber lens for turn signal)? if it is, check the double filament bulb for improper installation.
brake lights...
