Results 11 to 15 of 15
- Oct 2009
- 72
February 7th, 2010 12:02 AM #11The Bosch Red ignition coil has external resistor while the blue one has no external resistor. For the price i don't know the existing market price, but the red is much more expensive compared to the blue.
- Nov 2009
- 87
February 7th, 2010 12:37 AM #12" the ignition coil receives full battery voltage during start up for of course quicker starts, then when the engine has started and you released the ignition switch from start to run or on, the ignition coil receives a lower voltage because it is in series circuit with the resistor. if the coil has a resistor built inside, the available voltage at the output will be lower, hence the hard starting "
The above statement is not correct, misleading to newbie particularly
to those who dont fully understand the IGNITION SYSTEM of a vehicle.
Little knowledge is really dangerous and transmitting wrong knowledge to readers.
- Jan 2005
- 445
February 10th, 2010 09:55 AM #14Jick is right.
The original wiring for toyota point-gap includes a supply of 12 volts to the coil during startup, but once the start switch is disengaged, ignition switch provides the 12 volts to the external resistor w/c limits the voltage to the coil.
- Jan 2010
- 283
March 11th, 2010 05:38 PM #15
