Results 1 to 10 of 15
Threaded View
- Nov 2009
- 87
February 7th, 2010 12:37 AM #6" the ignition coil receives full battery voltage during start up for of course quicker starts, then when the engine has started and you released the ignition switch from start to run or on, the ignition coil receives a lower voltage because it is in series circuit with the resistor. if the coil has a resistor built inside, the available voltage at the output will be lower, hence the hard starting "
The above statement is not correct, misleadingto newbie particularly
to those who dont fully understand the IGNITION SYSTEM of a vehicle.
Little knowledge is really dangerous and transmitting wrong knowledge to readers.
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
