Results 1 to 20 of 20
    Jan 2003
    Hello fellow-tsikoteers. i just wanna ask what's the highest possible wattage, and good brand too, for my headlight bulbs without altering anything on my electrical wiring? im currently using stock bulbs and i want to replace with brighter specs. TIA.
    Philips Xtreme Power ^^,m +80%
    bro di na ba kailangan mag lagay ng relay pag palit nito, nalalabuan na rin ako sa buga ng headlight ko.
    Aug 2005
    Pilips XP has stock wattage, but brighter than stock.
    The wiring is designed for stock wattage plus safety margin. you can use higher wattage but you may remove or go over the safety margin of the design. Disadvange ay hi wattage bulbs ay madaling umitim ang reflector and maybe pati iyong lens.
    Sulit ang Philips XP or Osram nightbreakers. but still using stock wattage.
    Jun 2006
    You can put on the brightest bulbs...
    Just don't blind the oncoming motorists...............
    Aug 2005
    using the same halogen bulb type does not have much additional glare. wag lang baguhin ang aim.
    kahit stock wattage na halogen, kung itinaas naman ang aim equates to glare.
    Jan 2003
    Quote Originally Posted by docgorio View Post
    It's just that i think my lights are too dim for safety. so, i want to increase visibility for nighttime driving.
    Aug 2005
    Quote Originally Posted by conzky View Post
    Thank you sir.how much does Philips XP/Osram nightbreakers cost?
    Thanks also to others who replied.
    The XP costs about 1,500 per pair sa individual sellers. Night breakers is about the same. Sa blade, 2.2K+ ang 1 pair ng XP
    Ano nga pala ang gamit mong tint? Maybe ito ang cause kaya sa tingin mo ay madilim.
    Jan 2003
    55 watt HID kit ... they plug into the stock wiring so technically, it's not altering your original wiring.
    Jan 2009
    Installed in the stock "meant-for-halogen" optics? No offense GH, but you should know better.
    Jun 2009
    pwede po yun. yung vios ng tita ko ganon ang ginawa. more than 2 years na ok pa rin.
    Jun 2007
    Quote Originally Posted by ramledi View Post
    Probably 2 years of blinding incoming motorists as well.
    No moral judgements ... TS was asking a pure technical question.
Brightest Headlight bulb for civic
