Results 1 to 9 of 9
    Sep 2009
    Question lang ako mga boss,auto ko honda jazz idsi a/t 2005 model. Ano po kaya problema kasi yung gagamitin kona pag susi ko walang power as in yung walang lalabas na indicator sa gauge like battery,oil,etc. sa unang click ko ng susi,then pag start kona sya mismo ayaw din nya..wala syang power totally..
    Halos nagamit ko pa sya kahapon and okey naman..yung battery ko naman po bago lang 3months old palang..ano po kaya problema nun?
    Quote Originally Posted by oiknez View Post
    most likely, loose battery connection and or drained battery baka may naiwan naka on or nakabypass sa switch na electronics device.
    Sep 2009
    Quote Originally Posted by brainmafia_310 View Post
    Wala naman po ako naiwan na naka switch,actually sir minsan nangyari na sakin yung pag start kona sya yung tipong pag click kona yung susi para mag start ayaw pumasok ng power para mag start,gingwa ko tangal ko sa battery yung wire na negative and positive tapos balik ko ayun magkaka power,ma start kona sya ulit.. But now ginawa ko un ulit ayaw talaga as in walang power na pumapasok..may idea paba kayo boss ano pa prob?thanks..
    check the main fuses, minsan tricky baka naman busted. or check the wire ng battery baka ubos na ng omido yung positve terminal kaya may loose connectuion.
    Jul 2011
    Pa check mo sa battery shop, kahit 3 month pa lang battery pwede pa din yan masira, ung alternator pa check mo din baka hindi na nag charge. meron ka bang ikinabit sa electrical system mo na pwede maging cause to drain your battey try mo muna i-disconect.
    Oct 2009
    Kung merun kang voltmeter, check mo kung nasa 13v ang charge ng baterya.
    Feb 2009
    this sounds like a typical alarm activation result. check your anti theft system
    highly unlikely but a faulty ignition switch can cause the symptom
    meron kang el cheapo alarm? most probably yan ang cause. sira ang cut off.
no power,ayaw din mag start..pls help
