Results 1 to 9 of 9
- Sep 2009
- 45
July 12th, 2013 01:50 AM #1Question lang ako mga boss,auto ko honda jazz idsi a/t 2005 model. Ano po kaya problema kasi yung gagamitin kona pag susi ko walang power as in yung walang lalabas na indicator sa gauge like battery,oil,etc. sa unang click ko ng susi,then pag start kona sya mismo ayaw din nya..wala syang power totally..
Halos nagamit ko pa sya kahapon and okey naman..yung battery ko naman po bago lang 3months old palang..ano po kaya problema nun?
July 12th, 2013 02:01 AM #2
- Sep 2009
- 45
July 12th, 2013 02:13 AM #3Wala naman po ako naiwan na naka switch,actually sir minsan nangyari na sakin yung pag start kona sya yung tipong pag click kona yung susi para mag start ayaw pumasok ng power para mag start,gingwa ko tangal ko sa battery yung wire na negative and positive tapos balik ko ayun magkaka power,ma start kona sya ulit.. But now ginawa ko un ulit ayaw talaga as in walang power na pumapasok..may idea paba kayo boss ano pa prob?thanks..
July 12th, 2013 02:18 AM #4
- Jul 2011
- 1,711
July 12th, 2013 05:48 AM #5Pa check mo sa battery shop, kahit 3 month pa lang battery pwede pa din yan masira, ung alternator pa check mo din baka hindi na nag charge. meron ka bang ikinabit sa electrical system mo na pwede maging cause to drain your battey try mo muna i-disconect.
July 12th, 2013 06:31 AM #6
Kung merun kang voltmeter, check mo kung nasa 13v ang charge ng baterya.
July 12th, 2013 09:52 AM #7
Tsikot Member Rank 4
- 2,716
July 12th, 2013 08:55 PM #9
meron kang el cheapo alarm? most probably yan ang cause. sira ang cut off.
high idle RPM at engine start
