Baka grounded ka... me ikinabit ka bang accessories?
Hi Guys thanks for all the input, I finally got a replacement battery, my previous and now dead battery was called "Elektron NS-40" you guys have any idea about this brand? I replaced with a similar battery but the brand name was BK battery so just need your inputs if the new battery I got was worth it? cost me 2600 only
And is it true that a sure fire way of determining weather its an alternator or battery problem is after turning on the engine, disconnect the battery, if it continues to run then it was a battery issue, however if after disconnection and the engine dies right away then its an alternator problem? any truth to this?
This is mostly true with old school diesels. Some ecu of modern fuel injected(diesel or gas) requires regulation thru the battery hence would cut-off fuel once bat gets disconnected and rpm/current is not enough to sustain the solenoids of the pumps, injectors,accessories, etc.
Battery brands? If you pay peanuts, you get monkeys[emoji16] you get what you paid for.
actually, mayayari din ang alternator diodes ng mga old school diesel kung ginawa yang "troubleshooting" na iyan......marami pa rin ang gumagawa ng ganyang tipo ng electrical troubleshooting.
wala kasi pupuntahan yung current na napoproduce ng alternator (kung dinisconnect ang isang battery terminal with engine running) kundi dun sa kanya (alternator) mismo.
regarding battery brands, magbasa ka na lang sa isang dedicated thread na nandito sa electrical forum.
from a layman's point of view...
the battery plate chemicals turn brittle when in the discharged state, and can more easily break off and fall. the more they fall off, the less the battery's ability to hold charge.
in charged state, these same chemicals are not as brittle and do not fall off.
hence the importance of keeping your battery in charged state.
My MS battery is 3.5 years old.last week hindi na mag start.it need charging or replace a new one?any idea po thank you...
Bring your car to motolite. They have a tester that can determine if its the battery or alternator.
Need help guys, kaninang umaga lng ayaw na mag start ng auto ko (Avanza).... ano kaya possible problem? gumagana pa naman mga lights and radio pag naka accesories lang. Pero pag start na bigla na lng bumabagsak ang Rpm.
Before mangyari naka experience ako ng biglang bagsak ng Rpm to the point na parang mamamatay na yun engine. Pero nauwi ko pa naman din and knina lng na ayaw na mag start.
Thanks in advance.
I guess battery bring it to any motolite center. They have a tester for. Both battery and alternator
Service is free
how about fuel filter, baka dina dumadaloy fuel. Pero pag di talaga mag attempt ikot ang starter motor, then possible. battery, yung sa kin bago lang, gumagana ilaw, at alarm pero di maka pag start, after repalcement battery, ok na. on call naman motolite, so no need to go to their office. search sa internet at fb toll free nila for your local dealers.
