basically the alternator needs the battery to create the initial charge.. when you remove the battery while the engine is running, the alternator will charge will drop and may result in unstable voltage supply that can damage some of your electronic parts such as the ECU... the alternator needs the battery to create the charge unlike dynamos in generators which are self-exciting to produce the electricity
