Based on the 12v voltmeter I bought, the back print reads;
"engine off" 11.9 to 12.7 volts
"engine running" 12.8 to 14.4 volts
Scanguage is pretty much accurate than those plug-in-to-cig-lighter Voltmeters.
Keep in mind 13.8V is the ideal float charge for any 12VDC system.
In Telco and military -48V sytems its just multiple of 4, hence 55.2V
^its not that important to monitor it in milliVolts level
Whats important is one can deduce a dead cell of 2.1V from a total of 12.6V (6cells)
Sent from my SM-G532G using Tapatalk
mas madali yata ngayon bro ..
epsom salt to revive car battery - Google Search
Normal po ba na hanggang 3 buwan lang yung charge ng battery ng car? OFW kasi ako. Yung bayaw ko start lang every week ginagawa, di alam mag drive. Bago naman yung battery. Last January lang noong uwi ko.
i don't know.
my longest was one month. the battery wasn't anywhere near new, but the car (a 1.4 sentra) started easily.
maybe your bayaw isn't color-blind and knows how to handle a car battery charger?
but even if your battery drained below start-ability, you can easily charge it when you arrive, using a cheap charger from ace or handyman, for 15 minutes or so, so's it can be started. then, give her a spin for about an hour or so, so's the battery can charge fully.
had your car been a MT, i would have said, "the sentra is very easy to push-start, even if the battery is very weak".
Sa iba po, gaano po katagal bago madischarge yung battery kung hindi po napapatakbo yung car? yung car ko po kasi 3 months. normal po ba yun?
Wala po kasi ako s pinas, minsan after 4 months p ko nakakauwi. Thanks sa mga sasagot.
Smart charger. Sa shopee ko na bili. In Peso nasa 500+ lang.
eto sya:
https://shopee.sg/12V-6A-Fast-Univer...648.2125801345
