tsk tsk tsk tsk.... nakabili na ako ng motolite gold 2 weeks ago bago ko ito nabasa.
hmmm... loose connection lang daw . . .nothings wrong with the battery .... thanks
yun daw negative main line.. . .body ground... loose ang bolt sa body . .
importante din pala ung naka ground securedly ang negative terminal.
As I read through the thread, mas marami daw plates (13) ang Amaron kaysa Motolite, hence mas mataas ang current capacity nito.
Hindi kaya mahirapan ang stock alternator in my case Excel 2SF, dahil mas mataas ang current requirement?
Thank's po
hindi naman, your starter and other electronics still demand the same current. mas ok Amaron kasi it takes a lot to discharge.
kaya naman kung stock. basta hindi loose ok na. adjustable to a certain extent lang. In my case, nagpalit ako positive kasi maluwag and kailangan ng sheet metal para sumikip. teac Japan is ideal for me kasi pasok na pasok.
For the battery terminal clamps, ordinary tanso ok na right?
basta mapasikip ok na. I think stock can do the job. yung akin kasi siguro sa kalumaan naor something kaya ayaw na sumikip positive yung nagpalit ako Amaron.
Stock clamps pa rin ang gamit ko. Kailangan pa bang paklitan ito or liha lang?
As long as masikip pa clamps, ok pa yan. wag lihain kung wala naman problems.
No impact on the alternator, incase of discharge longer discharge time even longer charging time because of the capacity of alternator. The probability of a discharge is low because you have the same load or plus minus around 1% if you have minor mods like more powerful horn, higher bukb wattage but not hid or other.
But for the starter, it is a myth because the starter power is constant. meaning if 1sn is sufficient 1sn is sufficient, getting 8d will not make a difference to the starter except for the number of times the battery can start the engine without charging.
By the way, lead is 100% recyclable and would not make any difference if the lead is freshly mined under a certain mountain or recycled from other components, it is the design, manufacturing process and other stuff that makes a difference to prevent deterioration of components inside the battery.
Hth.
Sent from my GT-I9300 using Tapatalk 4 Beta
