Page 21 of 115 FirstFirst ... 111718192021222324253171 ... LastLast
Results 401 to 420 of 2297
    Dec 2002
    #401
    tsk tsk tsk tsk.... nakabili na ako ng motolite gold 2 weeks ago bago ko ito nabasa.
    Oct 2011
    #402
    sulit na rin yan sir pag umabot more than 3yrs MG mo.
    Apr 2013
    #403
    Quote Originally Posted by hammerhead2 View Post
    HEre is their number: 3946394. 2 Years lang warranty.
    Hello kaba yan,sana ka sa taytay,me from Barangay Santa Ana,query ko lang sana mo nabili yun amaron battery mo?
    Apr 2013
    #404
    Quote Originally Posted by bayen View Post
    happy to share na nag normalize na yung reading. 14.5 kapag running, 12-13.5 when engine off.
    Sir ano naging problema,voltmeter or alternator,anong ginaw ang remedy?
    #405
    hmmm... loose connection lang daw . . .nothings wrong with the battery .... thanks
    #406
    Quote Originally Posted by atongk View Post
    loose yung clamp?
    #407
    yun daw negative main line.. . .body ground... loose ang bolt sa body . .
    Oct 2011
    #408
    importante din pala ung naka ground securedly ang negative terminal.
    #409
    mas maliit kasi terminals ng amaron than motolite. Lalo yung Japan.
    #410
    As I read through the thread, mas marami daw plates (13) ang Amaron kaysa Motolite, hence mas mataas ang current capacity nito.
    Hindi kaya mahirapan ang stock alternator in my case Excel 2SF, dahil mas mataas ang current requirement?
    Thank's po
    Oct 2011
    #411
    Quote Originally Posted by [archie] View Post
    adjustable naman ang clamps diba sir?
    #412
    Thank's po
    hindi naman, your starter and other electronics still demand the same current. mas ok Amaron kasi it takes a lot to discharge.
    kaya naman kung stock. basta hindi loose ok na. adjustable to a certain extent lang. In my case, nagpalit ako positive kasi maluwag and kailangan ng sheet metal para sumikip. teac Japan is ideal for me kasi pasok na pasok.
    #413
    For the battery terminal clamps, ordinary tanso ok na right?
    Oct 2011
    #414
    Thank's po
    nahirapan alternator? hindi yan sir.
    #415
    basta mapasikip ok na. I think stock can do the job. yung akin kasi siguro sa kalumaan naor something kaya ayaw na sumikip positive yung nagpalit ako Amaron.
    Oct 2011
    #416
    Stock clamps pa rin ang gamit ko. Kailangan pa bang paklitan ito or liha lang?
    #417
    As long as masikip pa clamps, ok pa yan. wag lihain kung wala naman problems.
    #418
    higher capacity means good for the starter, which demands the highest load, and the same current for other load which takes a longer time to discharge, is a positive thing!
    but my worry is the current needed to charge the battery with our stock alternator?
    #419
    No impact on the alternator, incase of discharge longer discharge time even longer charging time because of the capacity of alternator. The probability of a discharge is low because you have the same load or plus minus around 1% if you have minor mods like more powerful horn, higher bukb wattage but not hid or other.
    But for the starter, it is a myth because the starter power is constant. meaning if 1sn is sufficient 1sn is sufficient, getting 8d will not make a difference to the starter except for the number of times the battery can start the engine without charging.
    By the way, lead is 100% recyclable and would not make any difference if the lead is freshly mined under a certain mountain or recycled from other components, it is the design, manufacturing process and other stuff that makes a difference to prevent deterioration of components inside the battery.
    Hth.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Jun 2011
    #420
    IMO sir i dont think that would be a problem...
    may Generator sets kami used for continous operation-- it uses two 4D BATTERIES... ang alternator nasa 65amperes lng...
Amaron battery
