Results 21 to 30 of 40
October 17th, 2015 08:57 PM #21
At rest a fully charged battery has 12.6 volts. It takes at least the battery voltage from the alternator to extinguish the charge warning light but it takes 13 to 15.1 volts for the alternator to recharge the battery. What chariot do you have?
BANNED BANNED BANNED
- Jan 2015
- 4,581
October 17th, 2015 09:08 PM #22
- Oct 2013
- 2,537
July 22nd, 2022 06:57 PM #25water resistant ba ang alternator??? kase baket ang design ng toyota (dihatsu) wigo / raize ay lagi nakikita ang alternator sa front grill ???
- 52,731
July 22nd, 2022 07:12 PM #26
- Jan 2008
- 4,726
July 22nd, 2022 09:06 PM #27
- Nov 2009
- 3,484
July 22nd, 2022 09:40 PM #29Splash resistant ang alternator usually IP65
Yung magnet wire ay laminated, bearings are double insulated, commutator is semi-sealed, rectifier and regulator are hermetically sealed but not the connections. Prolonged breach of flood water could damage those parts.
Usual nasisira ay regulator/rectifier, and if walang New Era replacement, better replace the whole assembly with Taiwan replacement.
- Sep 2021
- 758
July 23rd, 2022 08:04 AM #30
high idle RPM at engine start
