Results 21 to 29 of 29
- Jan 2007
- 137
September 4th, 2010 08:21 PM #21na-check ko na un terminal sa battery, removed it then cleaned it and re-installed it tightly. try ko un grounding ng (-) terminal battery going to the negative terminal ng alternator, not so sure kung san banda un negative terminal ng alternator, puede na ba doon sa bolt nya ?
- Jul 2010
- 570
September 6th, 2010 12:49 AM #22
- Jan 2007
- 137
September 7th, 2010 11:30 PM #23update ko lang...umilaw na un check battery then ayaw na mawala un check brake... pinapalitan ko na ng surplus.... ok na for now !:****:
September 7th, 2010 11:46 PM #24
- Jan 2008
- 4,726
September 8th, 2010 12:17 AM #25sa experience ko dati sa kia carnival nung mag over voltage yung alternator due to damaged IC regulator.. umilaw yung battery sign tapos umilaw yung parking brake light tapos yung ABS naman.. nung pinalitan yung regulator ok na
September 8th, 2010 04:09 PM #26
Incus,
Good charging of battery: 12.6 to 14.5 V. 2.1 V/cell x 6 cells = 12.6 V.
Over 14.5 V will deteriorate your battery due to oversupply of current.
If I were you pinalitan ko muna IC. Cheaper also. Pero ok na rin na pinalitan mo buong alternator tutal marami ka naman cguro pera. hehehe
September 8th, 2010 04:25 PM #27
ako buong alternator pinalitan ko.. meron akong nka tambak na alternator dito dko lam ano gagawin ko.
- Jan 2007
- 137
September 8th, 2010 11:24 PM #28napalitan na ng surplus (1,500 + 150 labor), pagnaka-idle 14.05, pag-on ng aircon at headlight 13.9... inabot ako ng halos 3 linggo para mag-decide kung papalitan ang alternator hehehe..sana nga maraming pera para mapalitan ko ng bago ang kotse ko ...lol !!
*gr3nd3l, ako din may naka-tambak na alternator dito 2 na hehehe... un isa try ko kung mapapalitan under warranty pa naman..try lang...hehehe
- Jan 2007
- 137
September 21st, 2010 04:56 PM #29pinalitan ng bago ang alternator (ishin denki) since under warranty pa naman. gawin ko na lang back-up just in case bumigay ang surplus.
Xiaomi E-Car
