Results 1 to 12 of 12
    Jan 2003
    how many volts ba dapat ang reading sa alternator.
    pinacheck ko minsan battery ko. when attached to the meter reader ba yon eto reading
    aircon on, radio on 13.5+
    aircon on, radio on and headlights on 12.6+ na lang
    also tested the battery using a digital tester (yung pang electronics ) and almost got the same reading.
    sabi nong mechanic mahina na alternator ko.
    totoo ba to or its just the battery?
    kng battery ang problem, pde pa ba ito i recharge?
    thnx in advance
    The 12.6v reading was probably tested while the engine was at idle.
    Normal readout with running engine usually at high rpm's should be 13.2-13.8v. Di kaya ng alternator yung current drain ng electricals, which is not normal on any average car. You could upgrade to a high amp alternator to sustain the voltage you car needs. Baka 45amps lang yan?
    normal lead acid voltage output is 2.2 volts x 6 cells = 13.2 volts.
    normal charging voltage of the alternator is 13.2 x 110% to 120% = 14.5 to 15.8 volts. any lower than 14.5 and the battery will be hard to charge. any higher than 15.8 and the battery plates will deteriorate.
    minimum charging voltage for a lead acid battery ("trickle charge" voltage) is 13.8 volts.
    so kung 13.5 lang voltage ng alternator mo then mahina na nga siguro.
    Aug 2003
    yup had a very similar problem. at idle, the voltage (no load) should be 14V or so. under load, at idle, it shouldn't drop below 13.5V or so (since as yebo points out 13.2V ang nominal battery charge). i tested this with a Fluke 85.
    it's misleading/leads to a false sense of security to measure the voltage at high RPM. ganun din ako noon. so what happened is that at idle (stop and go traffic) and full load, namamatay-matay ang radio ko. and some time later.. namatay makina tapos ayaw na mag-start (na-flatten yung battery).
    Jan 2003
    so dapat change na ko ng alternator? or pa check ko lang baka pde pa repair?
    Aug 2003
    i suspect the alternator is underpowered. in my experience, i tried to have mine replaced with a surplus unit of the same capacity. same problem, so it wasn't my original alternator. replacing with an alternator of higher capacity fixed the problem.
    if you are experiencing problems like: at idle, your dome light blinks in sync with your emergency flashers when at full load (e.g. full aircon, stereo, headlights) then your alternator is definitely under capacity.
    you can get a surplus unit for 2000 - 2500. although of course surplus yun, therefore swertihan lang. mga 6000 ang reconditioned. new -- di ko alam (20k daw ang new alternator ng galant!)
    Jan 2003
    k pa check sa weekend
    Dec 2004
    may kinalaman ba ang charge ba alternator sa bilis ng kotse?
    kapapalit ko lang ng surplus na alternator. parang napansin ko na nadagdagan ng 10 to 15 km/hr and takbo ko sa coastal rd.
    Dahil po kaya sa alternator ito? O masyado lang bumigat ang paa ko this past week?
    OT
    blkcoffe baka pigil yung ikot nung alternator mong una kaya hirap din yung makina mong ikutin yung alternator which affected ur speed. (just a speculation) :hihihi:
    Quote Originally Posted by blkcoffee
    Wala po ginanahan lang paa nyo sa pag apak sa silinyador.
    Pabuhay naman po nito....
    Yung nissan sentra ko na series 3 A/T po siya nabagsak ang voltage from around 14V to 12.5V at high RPM mga around 3000rpm po.
    Need help po kung may naka experience na din ng ganito.
    Apr 2009
    sa akin pinatest ko sa isang electrical shop. using the voltmeter.
    at idle, aircon and headlights on 12.6 volts pag nag rev ako abot sa 14 volts.
    sabi ng auto electrician mahina daw alternator ko need to fix daw. im thinking gusto lang ito kumita hehehe. kaya sabi ko palinis ko lang and change bearing.
    i will just wait hanggang masira tsaka ko na lang palitan, same din naman gastos nasulit ko pa itong luma ko.
    sa shops kasi sigurista sila ( minsan sa kita) gusto nila maayos talaga kahit d pa sira. taasan ko na lang idle ko para lumakas karga.. as long as pumapalo sya pag rev mo i think its fine na thats the old fashion way.
Alternator meter readings
