Results 1 to 14 of 14
Threaded View
    Apr 2009
    Quote Originally Posted by Mysticrhain View Post
    ... changed distributor cap ( had a crack in it)... The cars idling also seems erratic a times
    You basically have the same carb with my Mazda 323 Astina, only that my jets and barrels are bigger in diameter. Below are my two-cents worth as per experience on the carb.
    Anyway, how erratic is erratic? Going up and down? Frequently? With aircon on and off?
    AFAIK, carbs lose tune overtime especially pag may singaw na [SIZE=1](needs repair kit)[/SIZE] or depende sa atmospheric pressure [SIZE=1](cold/hot? - yes, hindi lang EFI ang affected nito)[/SIZE] at ambient temperature [SIZE=1](hot sunny day/cold rainy nights).[/SIZE]
    Ilang RPM menor mo pag may aircon at wala?
    May backfire ba (parang sinisinok or inuubo yung kotse)? If it backfires even on idle, have your air/fuel ratio fixed asap. It could cause overheat (mixed too lean).
    Na-try mo na ba i-remix yung air/fuel ratio?
    sprayed the carburator with carb cleaner
    Don't do this too often, especially spraying directly to the barrells without throttling higher revs. Your carb is downdraft. Now imagine where all that dirty slime go.
    Plan ko po:help next is to change the spark plugs and HT wires (4 years old din)
    Four-year old spark plugs and wires?
    I'm beginning to think this could be the culprit.
    Car runs fine, does not loose power or jerk but then it just stalls after several minutes
    How fine is fine?
    If it really doesn't "lose power" or "jerk", then rule out the backfiring issue.
    Does it eventually start after stalling? O hard starting na?
    napalitan ko na ignition coil niya pero nandun parin problema, kaninang afternoon, namatay makina, inalis ko isang spark plug niya at nong icheck ko wala spark, ngayung gabi nagstart uli oto
    How did you check if there was spark?
    hindi kaya distributor ko mismo deffective na?
    Diba kapapalit mo lang sir?
    Take it to a reputable shop sir.
    Good luck.
'92 kia pride stalling problem
