Results 1 to 7 of 7
- Feb 2009
- 29
August 5th, 2010 03:05 PM #1Hi to all,
I'm planning to change my current alternator rated 90A to 110A. Please Advice if this is OK....recently i have installed HID for my headlight....
- Jun 2010
- 47
August 7th, 2010 05:37 AM #2Good day yes you can, but you have to change your battery too, by 12v 110ah.
- Feb 2009
- 29
- Feb 2009
- 29
August 10th, 2010 05:41 PM #4is there a battery rated 12V 110AH? my current battery is having 12v 75AH....Please Advice..thanks a lot...
- Jan 2008
- 380
August 27th, 2010 03:58 PM #5You may have new alternator already but if you are still undecided, go for 110 amps, the one that gives high amps at low engine speed or idle as indicated in the specs otherwise baka sayang din. This should look bigger and heavier with bigger wires than low-amp alternator. You don't have to change the battery for this.
The other thing to consider is the pulleys should match at that rarting double belt na or 'B' size na yung belt na ginagamit.
Good luck.
August 27th, 2010 04:24 PM #6
Why would you need a new alternator? Hid systems usually have lower wattages compared to halogen? If indeed you have replaced your alternator, why would you have to replace your current battery? A good alternator has a cut-off when the battery is fully charged, especially IC types like those in the pajero.
I'am guessing your gonna get the one from the hyundai starex cause its a bolt-on to the 4d56, right?
- Feb 2009
- 29
September 1st, 2010 10:59 PM #7
Xiaomi E-Car
