Results 1 to 7 of 7
    Feb 2009
    Hi to all,
    I'm planning to change my current alternator rated 90A to 110A. Please Advice if this is OK....recently i have installed HID for my headlight....
    Jun 2010
    Good day yes you can, but you have to change your battery too, by 12v 110ah.
    Feb 2009
    Quote Originally Posted by gmd View Post
    thanks for the Advise...
    Feb 2009
    is there a battery rated 12V 110AH? my current battery is having 12v 75AH....Please Advice..thanks a lot...
    Jan 2008
    You may have new alternator already but if you are still undecided, go for 110 amps, the one that gives high amps at low engine speed or idle as indicated in the specs otherwise baka sayang din. This should look bigger and heavier with bigger wires than low-amp alternator. You don't have to change the battery for this.
    The other thing to consider is the pulleys should match at that rarting double belt na or 'B' size na yung belt na ginagamit.
    Good luck.
    Quote Originally Posted by neil_xtrm View Post
    Hi to all,
    Why would you need a new alternator? Hid systems usually have lower wattages compared to halogen? If indeed you have replaced your alternator, why would you have to replace your current battery? A good alternator has a cut-off when the battery is fully charged, especially IC types like those in the pajero.
    I'am guessing your gonna get the one from the hyundai starex cause its a bolt-on to the 4d56, right?
    Feb 2009
    Actually, my current alternator was being repaired 3 times already.....so i decided to replace the whole thing...the friend told me to replace my current alternator which is rated 90A to 110A...
90A or 110A for my pajero 4d56 TDIC
